I would use solid sweep along a path.
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-E1A36DCB-C629-44BE-9400-2D02D13CF7F4
If you either follow the tutorial above or just google "Revit solid sweep tutorial" you should be able to work it out.
i don't have your dimensions, but this is normal way to make your model because you have a groove in your model,with out groove you should use Swept Blend.
and this is your model with out groove in , I use some Reference Plane this is your choice to what you use:
Snipping Tool from microsoft:
but it has angled cut.so i use the Sweep,if i use the normal Extrusion then i must use the Sweep Void on it to make the angled cut on it.
