hi:
I am wondering if I can change and control the actual height of building pads to not carving the whole topography above it and just make a hole or envelope inside the mountain not on the surface
Solved by bimscape. Go to Solution.
Not with Building Pads
That's specifically what they are designed for- to modify the topography in order to create a horizontal plateu for your building.
Can you expalin the scenraio you want to create? ie what is it you are representing that remains buried under the topo?
yes, i want the halls to remain buried under the topography, I think there is no need for a pad in this case and just draw my walls and slabs on the correct levels as the topography is just a surface not mass?
Yes. ONly problem you will have is if you take a section through the topography / building, Revit will draw on the earth below- even though (as a 3D element) it is not a mass. So you may have to workaround that "graphical issue"
how did you managed to make topography over a building pad?
When I make hole in topo with building pad and paste earlier splitted and cuted surface it is going deep as main topography. Is there a way to control its depth?
I had to convert the top topography to a roof with the same material. See attached file.
