第 1 条消息(共 3 条)
I've got a few questions about building pads. I understand that building pads are used to cut through a toposurface and represent an excavated area. However, what is the pad itself used for and what does it represent? Can it be like a concrete slab or some sort of fill, like sand or gravel? Can't I just use the "split surface" tool to create another toposurface, delete it to create a void in the toposurface, and then use a filled region in a section view?. I think it would help me understand building pads better if I saw how they were used in a section view type. Thanks for any information.
已解决! 转到解答。
