Building is solid from inside in 3d view
Good afternoon,
Today i was working on my project but found out my building was solid from the inside so i cant see my components i drew with stabicad does anyone know how to open the inside?
TripleM-Dev.net
Did you modelled the building yourself?
Looks like it's a imported IFC, because of the color of the boxes (openings) at the windows, the grey solids would then be Area's/Rooms.
Or
It's a Mass?, select it and see what it is and turn if off.
- Michel
Set Phase Filter to Show Complete and see if that does the trick.
bill_gilliss
Hide the Ceiling category?
yes, it turned out to be my generic models that weren't correctly so i turned them off and everything is working fine now.
