Message 1 of 13
Building Elevations changing
- Mute
- Permalink
- Report
After the installation of the site contours the building levels changed from first floor 0'-0" to -106'-0" The Project Base Point is set at 106'-0" The Contour Labels Elevation Base is set at Survey Point. Site Elevation points were created as negative feet below 0"-0". Example 103 = -3'
This is a class exercise that I have used for 10 years and this is the first time this has happened. Two students have had the problem. We are using Revit 2020.
