Building Elevations changing
batied
Message 1 of 13
batied
After the installation of the site contours the building levels changed from first floor 0'-0" to -106'-0"  The Project Base Point is set at 106'-0"  The Contour Labels Elevation Base is set at Survey Point.  Site Elevation points were created as negative feet below 0"-0".  Example 103 = -3'
This is a class exercise that I have used for 10 years and this is the first time this has happened.  Two students have had the problem.  We are using Revit 2020.
Replies (12)
Message 2 of 13
Not following.  What do you mean by "installation of site contours"?  Also, if your Level is reading negative 106' -0", and the Level is relative to the Project Base Point, then the Project Base Point Origin is 106' - 0" ABOVE the Level.
Message 3 of 13
syman2000
Post up the file so we can take a look.
Message 4 of 13
_Vijay
yes, it's kind of strange. if you show some images it will be better clarify for assisting.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 5 of 13
batied
Attached is the student project and my project.  Note the differences in the levels.  They are the same difference, but obviously different.
David
Message 6 of 13
batied
Here are my project and my student project.  Note the differences in the levels.
David Batie
Message 7 of 13
batied
Batie, David L has shared OneDrive for Business files with you. To view them, click the links below.
[https://r1.res.office365.com/owa/prem/images/dc-generic_20.png]
Student - FINAL PROJECT.rvt
BATIE - FINAL PROJECT 005.rvt
Attached are my final project example and my student's project. Note the differences in the levels.
David
Message 8 of 13
Here's what is going on between the two projects. See attached screenshots.
Message 9 of 13
Message 10 of 13
batied
I see the difference but how do I fix the student’s model to look like mine. I do not see differences when looking at the Survey Point Internal.
Message 11 of 13
Well, if you don't want to move the PBP and SP, then change the Levels' Elevation Base in one of the Projects. Project Base Point to Survey Point, or vice versa.
Message 12 of 13
Message 13 of 13
Move you student's model Project base Point and Survey point 106' down.  File attached.
