- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I have an issue with the view range showing Detail Level: Fine for Walls. This seems to be a Bug or something that I came across it. I have drawn few walls of height 2000mm & the view range: Cut Plane is set to 1500mm the wall layers are visible clearly. When the wall height goes below 2000mm i.e. 1900mm, 1800mm the wall layers are not visible. When we draw a wall of height 1000mm & view range: Cut Plane is set to 600mm still the wall layers are not visible in Detail Level: Fine. I have attached a video clip below for better understanding.
Can someone help me with this? Is this a bug or does Revit works like this?
@revit @revit
