Bug with the Visibility of Nested Elements in a View
- Mute
- Permalink
- Report
I’ve discovered a bug in Revit related to view settings and would like to share it. I already raised this issue in a previous thread (https://forums.autodesk.com/t5/revit-architecture-forum/view-filters-for-shared-nested-families/td-p...), but it was ignored. I believe this is an important problem and should be addressed. I’ll try to describe it as briefly and clearly as possible.
There is a “Family1” with the category Mechanical Equipment and a “Family2” with the category Pipe Fittings. “Family2” is a shared family nested inside “Family1.”
If you hide the Mechanical Equipment category in the Visibility/Graphics settings of a view, only “Family1” will disappear. This is logical and works as expected.
However, if you apply a view filter (even without conditions, just a filter with the Mechanical Equipment category) and then disable its visibility, both families will disappear — “Family1” and the nested “Family2.”
I believe this is clearly a bug and shouldn’t behave this way
