- Mute
- Permalink
- Report
I have a file here, a Revit Project File with a linked IFC file.
(I have tried to attach the files in a reply to this post, but somehow I cannot attach the IFC file so here is a download link for the two files: https://we.tl/MPocUCLhrU).
The Revit Project File shows some weird behaviour that I can not explain. I was wondering if anyone out here could help out, to define what's going on.
To reproduce my issue, please execute the following steps:
-first link the IFC file into the Revit Project File
Now, first issue
-go to the view "1 - Floor 1" (floor plan)
-when zoomed out I see this (pic01):
pic01
-then, when zooming in, some parts are falling away ! (pic 02) Why is this happening ?
pic02
Second issue:
-go to view "2 - East" (elevation view), then go to view "Section 1" (Detail View).
-Inside view "Section 1", with the Far Clip Offset on default value 3048 everything is visible. I am seeing this: (pic 03)
-But, when changing the Far Clip Offset to 50 mm , again, some things are falling away. I am seeing this: (pic 04)
These are just two examples but it's happening pretty often. (Always using the same Project Template File. So maybe it could be related to that somehow?)
Furthermore, the behaviour seems inconsistent. Regarding the Second issue from above, just a few moments ago, at Far Clip Offset value 50, the linked ifc model was falling away as well. But I cant reproduce that anymore.
Does anybody have any idea what is going on here ???
Thanks in advance!
