Broken Material Library
The server in our office has changed so it has broken all of the links for the images to materials. Is there a quick way to re link all material files across the whole library as oppose to going through everything? And am I missing something key in re-saving the library back down to the server?
Lewis
Alfredo_Medina
@Anonymous
Welcome to the forum,
if you are referring to custom materials, used in multiple projects, I don't think there is a quick way to fix that. I think you need to fix that as you go into every project and see that a material doesn't render properly.
If you are referring to materials in the default library, that could be fixed by re-installing the Autodesk Material Library from Programs aand Features
