bringing details line in front of picture on a title block
danezeq
Message 1 of 8
danezeq
Does anybody has a clue why it is not possible to bring thing line in front of this picture on the titles block?
https://www.youtube.com/watch?v=lFiLCIel2a0
Replies (7)
Message 2 of 8
ennujozlagam
you can't do that in your project file, you need to go your title block family and put the line there and load again. thanks
Message 3 of 8
danezeq
I draw this line on the project file in purpose of show which part of the thumbnail is visible on the sheet. it is a splited plan into 4 sheets.
That why i have to sketch it on the sheet, on the project file.
Message 5 of 8
danezeq
I already used matchlines.
Sorry for my English, sometimes it gets diffucult to explain the issue.
Just look at this screenshot: the red lines are matchlines, the green lines are lines i want to draw on 4 sheets.
Message 6 of 8
ennujozlagam
I'm assuming you want to create a key plan??? you can create a detail lines with yes or no parameters. you can also do that in your title block family filled region with yes or no parameters. thanks
Message 7 of 8
martijn_pater
Ah, you want to have an indication in situation. I create a legend view for the situation drawing and place that on the sheets and then draw the indication on that.
Message 8 of 8
Same exact situation.
Of course it is not possible the straightforward way, like in AutoCad or any other program.
