Brick wrapping at curtain wall
8 REPLIES 8
Message 1 of 9
2638 Views, 8 Replies
I have attached a image of my proplem. I have two walls on top of each other, the bottom wall is correct but the top is not. The curtain wall is embedd in both walls but the brick is only wrapping bottom half. Their is no wall openings either. Any suggestions how i got bottom half to work, so i can do the top half as well?
8 REPLIES 8
Message 2 of 9
Is it a different wall type because of the reveal?  Check to make sure you have Wrap exterior enabled for that wall type.
Message 3 of 9
RDAOU
@Anonymous
As @Anonymous mentioned ... check the wrapping is set for exterior.
What I actually wanted to add is that (from finish where the reveal cuts the wall) they are not stacked nor compound; they actually look like the same wall literally placed one on top of the other
  • If the are the same why not just use 1 single wall instead of 2 on top of each other? This would fix the finish at the reveal cut at the same time
  • if they are different and have something special in the Type Structure...why not use compound or stacked type? ( in the case of the latter; you have to set the wrpping in the original wall types being stacked)
Message 4 of 9
Same wall type, I do not get the pattern when I have it exterior wrapping, just the color of brick
Message 5 of 9
Nevermind, that only at shaded view setting thanls
Message 6 of 9
Keith_Wilkinson
Not sure that answer will help anyone else looking at the thread...  😞
In my experience if you allow curtain walling to auto embed, Revit ignore the wall closures so you get what you see at the top of your original image.
We circumvent that by using a wall opening first and then adding the curtain wall second - this gives us a number of advantages as we can set the size of the opening to specific brick dims for example and then ensure our curtain wall fits accordingly - it also gives us the correct wall closures so everything 'looks' correct as well.
It would be helpful to know how your original model is put together to understand better why you have different conditions top and bottom.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 7 of 9
in reply to: Keith_Wilkinson
The method of editing the wall profile first (or adding a wall opening) definitely helped with the brick wrapping at curtain walls in our project. Thanks for the tip!
Revit seems very fickle about when it chooses to add the material wrapping. Sometimes it worked and sometimes it didn't. Also walls would have the correct wrapping then for some ungodly reason the wrapping would disappear the next day! The above workflow works a gem.
PS. I'm pretty sure the people at Autodesk who are responsible for creating curtain walls and stairs are deliberately trying to make our lives hell! These elements have a mind of their own and are hopeless at integrating with other components. Maybe......one day they will sort it out
Message 8 of 9
Guys the tip of using a wall opening or even editing the wall profile doesn't seem to work for me. I am using Revit 2019. The only solution I'd have right now is adding invisible doors or windows..
Message 9 of 9
I solved my problem.
The problem was the wall itself. For some unknown reason wrapping doesn't work well for the type of wall I used. I created a new wall and your tips finally worked.
Forma Design Contest
Technology Administrators
