Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am trying to wrap this double hung w/ half round window with a brick Solider via a sweep. You can see that the top of the arch is working fine, but when the sweep reaches the straight sides the brick work is going the wrong way.
I need the brick solider course to continue on as I have indicated with the red lines on the right side of the screen shot.
Solved by ToanDN. Go to Solution.
Hi, @atishTL3Y8
The trick to do this is to use, for the arch, a profile that is not rectangular, but with a tiny inclination:
