Breaking railing baluster pattern at an angle greater than
Message 1 of 9
Hi, while creating railings, I tried to break the baluster pattern at an angle greater than 45, but the pattern disappeared when I add a segment less than 45 instead of being broken, how would this be solved , any idea?
Replies (8)
Message 2 of 9
_Vijay
Try with Other baluster types...if came the current baluster panel need to be review.....
Try and let me know your comments...
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 9
Looks like it is doing exactly what you want.  Are you saying you don't want the baluster pattern to stop at 45 degrees angles?
Message 4 of 9
Hi, the baluster pattern should break at 45 degrees, and then start a new patter. What happened is that it stopped and I do not have any balusters at all at the segment!
Message 5 of 9
45 degrees is the point along a railing segment at which the baluster pattern stops.
Message 6 of 9
I tried, but same problem exists!
Message 7 of 9
The pattern should break and restart. It's not supposed to completely stop
Message 8 of 9
Break Pattern at Each Segment End  -- or Never.
Message 9 of 9
