Revit blocks 3d views by family editing
When I try to edit some families, the program blocks access to the 3d visualizations. How do I enable 3d access of these families?
RobDraw
It's probably not the program but rather setting(s) in the family. Find out what is blocking/controlling it and remove it.
Rob
Hello again,
Thank you for the answer, I'm lerning yet Revit, so my Revit knowledge are very poor yet.
I will try to find out what is the 3d view blocking control in the specific family, but if you can give me some kind of further tip, I'll apreciate.
Thanks again!
RobDraw
I could guess as to what the problem might be. I could give you a more accurate answer is I had access to the family.
Rob
syman2000
Really depends what family you are editing. If it is 2d detail family, you won't have access to 3d view.
Check the Visibility Settings of geometry in the Family (e.g. Detail Level).
