Hi, I have an issue here.
How do I make the Bracing (the X dotted line) always appear in the even number of the array family?
Thank you
Solved by barthbradley. Go to Solution.
Solved by rxi.gg. Go to Solution.
Can you upload the family to check it?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Make it as a second array. Place the first one on the second of the first array, place the second one on the fourth of the first array, and write a formula so the correct number shows.
You'll need to use visibility parameters and a second X for cases where there is only one.
Why don't you array two elements - one with "x" and one without?
...Or just make the "x" a separate Array?
I upload you the family edited. I create a new parameter and a new array for the lines
@barthbradley wrote:Why don't you array two elements - one with "x" and one without?
- cannot 2 elements because sometimes odd number of elements might happen.
- yes, need to separate array for X, but seems like bro @rxi.gg have solved my problem. 😁
Glad to read that! Please, Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt!
- cannot 2 elements because sometimes odd number of elements might happen.- yes, need to separate array for X, but seems like bro @rxi.gg have solved my problem. 😁
If you are interested, check this revision out. A added a few parameters to make it flex better. You needed some way to deal with a <2 Array, which Revit won't allow. Open the revised RFA from the attached RVT.
wow. This is the complete solution for my case. haha 😲
The solution from @rxi.gg already solved my main question for this Posts.
Yet the minimum element can be shown is only 2. If less than 2, it will clash and have to delete the family or keep it 2 elements. My idea to solve this issue is to create another family for single element only.
But seem your solution already solve my second issue. Now I need to understand the formulas in the parameter. 😂
Thanks bro!
