Brace Symbol Location Changes when column height changes
joakes-DE
joakes-DE
These braced frame brace symbols display as expected in plan (LEVEL 3) with the following View Range settings:
Elevation:
Plan:
But when I raise the column above LEVEL 3 the brace symbol moves to the center of the beam:
Elevation:
Plan:
Can anyone explain the behavior here and possibly provide a solution to get the brace symbol to keep the desired location (stay at the column and point "down" like the symbol on the right)?
joakes-DE
From what I can tell, this point right here is driving the display. Once this point goes above the "Associated Level" for a view, the brace symbol is displayed as going "up".
Still hoping for a solution. 😂
navya_gelli
Hi @joakes-DE ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Navya | Community Manager
joakes-DE
@navya_gelli I don't have a solution yet. Still hoping the community has something.
