BPAC certificate completed WITH NO CERTIFICATE PLEASE HELP
Please I need support,
I just finished Autodesk Building Performance Analysis Certification courses. After I completed the mandatory survey in the end of 7 courses I noticed that to write the code as it is appear, but there were no codes, then I went through the next page (Final BPAC Quiz) then, Failed. I cannot take the certification tell I complete (Final BPAC Quiz) which need the mentioned code.
Please advice.
Please advice.
Read through the other post that you just commented in.  Your answers are there.
Thanks, Problem solved
What is the solution to this? If you missed the code which you have to enter for the final BPAC quiz?
Just send an email to bpac team and they will solve the problem.
