boundry lines of a callout
babysatch
Message 1 of 8
babysatch
is there anyway to display the boundry lines of a callout as dashed lines, whenever an Element is cut. I would like to draw a dashed boundry line with an overhang of say 1,0 cm. Is it possible to do such a thing with revit?
At the moment all I can get out of my sheet is the callout without any boundry lines, which you can see in the file "Project1.pdf".
As an example of what I would like to have see the file "Project2.pdf" please.
Thank you.
Replies (7)
Message 2 of 8
Darin.Green
The only way I can think of is to draw detail lines using the Hidden line type which appears as if that's what you did.
If this information was helpful, please consider using the Accept Solution
Message 3 of 8
babysatch
...thank you for your reply.
But imagine I would have a very large complex with hundreds of sections and call outs per level. I thought there must be some way to define a family or parameter or something similar to automati zeller that.
Message 4 of 8
babysatch
Betont draw hundreds of lines would be painful.
By the way I draw the dashed lines in the attachment by adobe acrobat pro.
Message 5 of 8
babysatch
To draw hundreds of lines would be painful.
Message 6 of 8
babysatch
Sorry for the typing errors 😞
Message 7 of 8
Darin.Green
No worries... Another think you could do is select the Crop region, then right-click and choose "Override Graphics in View > Element. This will allow you to set the line type to hidden, but it will be the entire cropped region without the overhangs.
Message 8 of 8
babysatch
Perfect. Thank you.
