- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have two problems here –
Firstly I am finding that when I set a bottom view depth, Revit will actually show slabs that are close to (but not actually included) in that view range. So if I set the view range to 1800mm below level 2, if I have a slab that is 2200mm below level 2, I will actually see that slab even though it is not actually within the view range I set.
Secondly the same applies when I have a ramp from the level below my current view, travelling up to the level of my current view. Instead of the bottom view range cutting the ramp part way down the ramp (which correctly happens if the ramp is travelling past my top view range going up to the level above) the whole ramp from the floor below is shown, which means my linework does not look right as I have dotted lines underneath my slab (IE: showing the base of the ramp on the floor below).
