I've uploaded two files, the 2017-25 one is the one where I had the original issue, as a workaround I set a lower rail as a capping to the stringer, it works but the height of the bottom rail needs adjustment for each pitch which is not ideal.
The 2017-37 file is another file with similar features, this has a half turn winder stair, Revit just cant do the stringer/handrail as its built and the winder stair tool won't allow the stair support/railing to be created with this geometry. The stair exists, (photo of actual stair also attached), and is compliant with current regs so I think the software should be able to model this condition given its cost.
I guess my questions are:
How do you get the balusters to cut at the stringer/support without the bottom rail workaround
How do you get the stringer/rail to work at a winder stair with tight geometry
How do you set the lateral offset of the stringer, the control is greyed out. in this case I altered the sketch
