Bolts to glass stair treads, parametrically
yes_and_no
Message 1 of 14
yes_and_no
Guys, is there a way to parametrically array the bolts to the treads automatically, inside the stair family (in stead of MIP, model in place) as attached.
Replies (13)
Message 2 of 14
Add the bolt to the baluster family.  Set the railing type to have 2 balusters per tread.
Message 3 of 14
yes_and_no
Thx Toan, for presentation purpose, I m good to go, see attached.
But, for insanity:
no matter how much I change the balluster family, the bolts won't get pass the glass surface, can't you help here.
Message 4 of 14
syman2000
Post up the family so we can take a look.
Message 5 of 14
yes_and_no
Here is the file, in R17.
Actually another issues I have is connecting the handrail extension that won't match 30" ht of the hosted rail,  and 2) making the middle stringer as big wood in R17 as attached pic.
Message 6 of 14
Is that a Start Post?  Try a Top Offset value.
Message 7 of 14
How do you mean?  Got pictures or file?
Message 8 of 14
yes_and_no
That is the right parameter, but it won't match the height perfectly, it can be up or down a bit more or less. I turned around editing the profile family, but Rv won't accept when loading it back.
Message 9 of 14
I just tried and it seems to align perfectly for me using Top Offset. What's your Top Rail?
Message 10 of 14
yes_and_no
M_circular Handrail: 40mm
Message 11 of 14
Like this?
Add a teeny tiny extension to the rail sketch. Set its Slope to Flat.
Message 12 of 14
yes_and_no
I tried, still not working.
Can you post the files, I wd like to check side by side what wrong with mine...
Message 13 of 14
Message 14 of 14
yes_and_no
I understood what barthbradley said. I tried, many times, look like his Rv is better than mine, being post R17.
