Section box poche with linked models
dgoff96
Message 1 of 8
dgoff96
I've been trying to create a rendered section perspective with enscape following this example, however seems it doesn't work with linked models. I can do it in a straight up revit view by overriding the cut patterns, but that won't render in enscape. Am I missing something with the poche settings to make them apply to linked models?
Replies (7)
Message 2 of 8
Have you added Poche material to the linked models?
Message 3 of 8
Which part can't you do in Enscape?
Message 4 of 8
dgoff96
Enscape won't render the poche material at the cut plane when cutting through linked models. It will for native non-linked objects
Message 5 of 8
dgoff96
From what I understand, you tell it to use the material through the view type properties:
It just seems to ignore linked models
Message 6 of 8
I understood that.  Can you add the same Poche material to the linked models, save and reload them into your main model?
Message 7 of 8
Could be related to View Phase Filter.
Message 8 of 8
fortunato.velletri
To make the links model work, simply edit the poche materials individually within the linked file.
