Hello, I am having a hard time changing the color of the blue lines for windows in the elevation sheet. Is there a way to change the color of the operable lines in Revit for windows to black without making the entire document black and white in the elevation view?
Solved by barthbradley. Go to Solution.
"Operable lines"? You mean "Swing lines"? Can you TAB-Select them in the View and use Override Graphics in View By Element or By Category on them? If not, you'll need to go to the source to change them and/or make them changeable in the Project. Post the Family here if you need help.
Thank you, I had to go into the family and make a new subcategory for the line to change but I figured it out!
