Bloated PDFs generated from interior elevation sheet.
Sahay_R
Mentor Mentor
Message 1 of 24
Sahay_R
What could be the cause of bloated PDFs? An interior elevation sheet with all the non rectangular crop regions reset still prints out to a larger pdf than it should! What else should be checked out?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Accepted solutions (3)
Replies (23)
Message 2 of 24
cbcarch
-How many views are on the sheet?
-Fine Detail Level?
-Lots of Fill patterns, filled regions and/or masking regions?
-View Templates applied to limit number of categories on in views?
-Lots of Linked Revit files? If so, how about VG settings for them?
-Linked Cad?
-Raster Images?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 24
If it is forced to print as Raster then the PDF file size is much bigger than Vector.
Message 4 of 24
Sahay_R
Thank you @cbcarch. So do you recommend that the view template keep all categories on, with display being controlled by filters? I would not be surprised if that were a part of the problem.
@ToanDN - I will check with the person who generated the prints. When I created the PDFs they are smaller than what I see in the Project folder.
Rina Sahay
Message 5 of 24
Sahay_R
@cbcarch - Cliff, when you mention fill patterns, regions, etc does that include painted on materials?
To answer your questions -
Fine detail
Some filled regions - maybe 2
View templates do control categories
Only 4 linked Revit files
Yes to linked CAD, also imported in families.
No Raster images
Rina Sahay
Message 6 of 24
cbcarch
-Yes--materials painted onto elements can use a lot of resources when printing.
-As mentioned by others, Raster vs Vector can affect output file size, as well as printer driver use and other settings such as "Presentation Quality", Color vs Black & White, etc.
-Are you printing Hidden Line Views?
or Shaded, Consistent Colors or Realistic with shadows, etc.?
Cliff B. Collins
Message 7 of 24
Sahay_R
@cbcarch - hidden line views - I'm not brave enough to try Shaded or above....
Rina Sahay
Message 8 of 24
cbcarch
Just curious--
-Have you experienced this on other projects, or just this one?
-How much RAM does the machine you print from have?
-Do all users experience the file bloat?
- Are you using a PDF plug-in, like Acrobat or Bluebeam?
-Raster or Vector settings?
Cliff B. Collins
Message 9 of 24
Sahay_R
@cbcarch -
Just experienced on this one
32 GB of RAM
This is the first time I have heard of file bloat since I started here
PDF plugin that I am using is Foxit Phantom PDF
Printing to Vector
Rina Sahay
Message 10 of 24
Sahay_R
I'm stumped - I've reset the crop regions, removed any fill patterns - painted and regions - and nothing has changed....and these are the print settings that I have been using -
Rina Sahay
Message 11 of 24
Post a bloated PDF file here and we shall see.
Message 12 of 24
Sahay_R
@ToanDN - here you are.....in all 2238kb of its glory.....
Rina Sahay
Message 13 of 24
cbcarch
Have you tried Color or Black Lines instead of grayscale?
Cliff B. Collins
Message 14 of 24
Sahay_R
@cbcarch - No, not yet. However, bumping down the detail of the views from Fine to Medium halved the PDF size.
Rina Sahay
Message 15 of 24
cbcarch
So my reply #2 above solved it?
Cliff B. Collins
Message 16 of 24
Sahay_R
@cbcarch - partially - the sheet is still above 1MB. Similar sheets from comparable projects (similar size, content, families, number of views, identical view template and print settings) are still smaller than that - hence the concern.
Rina Sahay
Message 17 of 24
cbcarch
Were the other jobs printed in grayscale as well?
Any reason for using grayscale?
Cliff B. Collins
Message 18 of 24
Sahay_R
Yes, they were. Our office standards are to greyscale things that are NIC for the GC.....
Rina Sahay
Message 19 of 24
cbcarch
Perhaps you could use a Filter for the grayscale, with parameters for the elements which are NIC?
This way you could use normal black lines print settings and it might reduce the PDF file size.
Cliff B. Collins
Message 20 of 24
Sahay_R
Tried that, @cbcarch. Both B/W and greyscale give me the same PDF file size......
Now - would editing image resolution in the Printer Properties affect the quality of the output?
Rina Sahay
