Binding All Design Options
I created a floorplan with 2 options for 2 separate addition. These addition are set up as design options and i can turn them on and off. However now i need both additions to show at the same time, is there a way to bind both design options into the base floorplan?
Can this be done without redrawing either or both of the additions. From my understanding by making one design option primary, the other design options will be deleted, is there a way to make both design options primary?
artejon
if you want to see both options at the same time you will have to copy/paste elements from one design option:
- to the other option
- or copy to a main model.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Why did you use Design Options if the additions are not Options? Unless there are there two Options for each Addition.
