BIM Object Website
17 REPLIES 17
Message 1 of 18
3024 Views, 17 Replies
BIM Object Website
Has anyone used the BIMObject.com website?  Some great stuff on it but I am struggling to get anything to work.  I'm particularly interested in the facades by Steni.  It has a downloadable add in to allow you to use their products easily.  Looks great in the YouTube vid but now I've downloaded it I can't find out how it actually loads into my Revit tab?  The NBS, KCL and BIMobject ones have automatically done but not the Steni installer.  Any clues?
17 REPLIES 17
Message 2 of 18
robert.klempau
Hello @Anonymous,
I see you use Revit 2017.
when I look at Steni System Solution on BIMObjects I see that it is supported for Revit 2013 till Revit 2016.
"This is an add-in installer for Revit 2013 - 2016."
Please contact Steni System Solution and ask them when the 2017 version is available.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
Message 3 of 18
robert.klempau
Hello @Anonymous,
Did you manage to get it working?
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 4 of 18
in reply to: robert.klempau
All sorted now, just had to put it in the right 2017 folder and rename the file.
Message 5 of 18
I'm having the same problem of using STENI add-in for revit. I did put it in the 2017 file but as u mentioned rename, can u tell me which file do i need to rename?
thank you
Message 6 of 18
williamsosei66
please im having the same problem, can you let me know what file you renamed and what you renamed it to
Message 7 of 18
aymen03
Hi, How can we change the name to solve the probleme ?!
Message 8 of 18
roy
Community Visitor
Hi, can you please tell me where to save the installation file ?
Having the same problem with Revit 2017..
Thank you.
Roy
Message 9 of 18
Thank you Sir for your response, I check phasing and discipline  but didnt get any solution,
I f you have any solution please let me know.
Message 10 of 18
Hi, Can you please tell me how to change the name of the files in Steni, so that you can add in the Steni app into your revit program? I am using Revit 2018 and it seems that the Steni file is for 2013, 2014. Please help me to solve this problem. I attached the error detail.
Regards
Message 11 of 18
Hi can you help ? The frame family doesnt exist in my revit 2015. Thank you
Message 12 of 18
Please I'm having problem with steni product with my revit 2017 apps.can anybody help out please it's very urgent.
Message 13 of 18
Please how did you work it out.
Message 14 of 18
Has anybody been able to get the Steni Facade Add in to work on Revit 2018?
Be very grateful for your help.
Best regards
Message 15 of 18
robert.klempau
Here is the 2017 version and install instruction.
See attachment.
They are working on a 2018 version.
Kind regards,
Robert Klempau
Cadac Group AEC BV
Message 16 of 18
thank you very much for reply, have install it and is working perfectly now.regards
please sir can you give and explain other add in apps apart from steni facade.
thank.
Message 17 of 18
Thank you so much. It's working!
Message 18 of 18
Hello
Please I need steni facade panel plugin for Revit 2020
