How to Remove Cut-out in roof
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
info
905 Aufrufe, 5 Antworten
Someone have given me a roof with a cut-out,
I'm guessing they have used an "opening" of some sort to create it.
Please find attached
How can I I remove it?
5 ANTWORTEN 5
Nachricht 2 von 6
constantin.stroescu
als Antwort auf: info
just select the cutout and delete it..
Constantin Stroescu
Nachricht 3 von 6
constantin.stroescu
Nachricht 4 von 6
info
Thanks for that. I didn't realise it was that easy.
I have the same roof, but with another joining roof (this configuration was originally presented to me).
What's the easiest way to connect both roofs as seamlessly as possible?
So the joins can't be seen from underneath (the roof) - i.e. you can't see the joins in a sectional view?
Nachricht 5 von 6
constantin.stroescu
in attached screencast I've shown some ways of doing these operations ...if Join Roof operation fails to smooth align the two roofs, then you can use a Void to Cut the extra roof after simple Joining.
https://www.youtube.com/watch?v=evZGrhHIYvs
Constantin Stroescu
Nachricht 6 von 6
info
Thank-you Constantin for taking the time to put together that video,
I learnt something from that.
