Best Wall TV / Monitor for an Architectural Office Conference Room running Revit
KKProssick
KKProssick
The is a TECH question so I hope it is in the right location, please redirect me if not.
My architectural firm is looking for the best affordable wall mounted tv / monitor for our conference room that lap tops and tablets could connect with while sitting at the table.
Mostly used for presentations and model walk thrus with clients.
Any suggestions.
What would be the minimum requirements? Resolution? Connectivity? Affordability?
What do you use?
Viveka_CD
Hi @KKProssick
@Anonymous has a good explanation of related information on this thread
KKProssick
Thank you. I will take a look.
If you are an architect looking for a monitor for yourself, the Sceptre IPS 24-inch business monitor will definitely grab your interest. With its incredible and edgeless design and an wonderful resolution of 1920 x 1080 FHD with IPS panel and wide screening angles, it give you an remarkable display with an thrilling experience. This monitor has various ports, so it will totally suit your requirements if you wish to attach your devices for your architectural work.
