what is the best book to learn revit? starting to advanced all commands? i usually learn softwares from the Dummies series. they are really good. on amazon i saw revit - no experienced required, and mastering revit architecture series. which is the best one of them?
Solved by msgambelluri. Go to Solution.
Solved by BIMologist_. Go to Solution.
Solved by Viveka_CD. Go to Solution.
Solved by Paul_F_Aubin. Go to Solution.
i think
Mastering Revit Architecture is the most wonderfull book
alse
the help itself of revit
try to find Mohamed El Masri Course this is arabic Course will provide you with more info than expected and LinkedIn Learning courses
I just released one of the first Book on Dynamo for Revit
It is available here
https://www.aeccheatsheets.com/dynamo-and-grasshopper-reference-ma
Marcello Sgambelluri
I strongly recommend this book "Residential Design Using Autodesk Revit 2021" authored by Mr.
Daniel John Stine as the best book at all for beginners like me to learn Revit Architecture 2021, I encourage my colleagues to own this valuable book by the following link:
https://www.sdcpublications.com/Textbooks/Residential-Design-Using-Autodesk-Revit/ISBN/978-1-63057-3...
Kind Regards
Revit 2022 is here!
Check out the below links: 🙂
https://blogs.autodesk.com/revit/2021/04/06/whats-new-in-revit-2022/
System requirements for Revit 2022 products
https://www.autodesk.com/products/revit/new-features
What's New in Revit 2022 Sneak Peek - YouTube: https://www.youtube.com/watch?v=FjSbv6W6tcg
Revit 2022 - Amazing New Features! - YouTube
https://revitpure.com/blog/revit2022
https://www.linkedin.com/pulse/whats-new-revit-2022-paul-aubin/
https://blog.bimsmith.com/Whats-New-in-Revit-2022-Top-New-Features-in-Autodesk-Revit-2022
https://bimchapters.blogspot.com/2021/04/revit-2022-see-whats-new-in-my-annual.html#more
Thank you Authors! Paul Aubin @Paul_F_Aubin, Dan Stine @dan.stine
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Thanks for the mention
Paul F Aubin
Author/Consultant
Check out my books and training videos
paulaubin.com
Thanks @Viveka_CD! Also, since this is the "books" thread I should mention all my Revit 2022 books are listed here: https://www.sdcpublications.com/Authors/Daniel-John-Stine-AIA-CSI-CDT/1/ 🙂
Thanks @dan.stine Looking forward!
Viveka CD
