Bending extrusion with pattern
Message 1 of 35
Hello, I have a panel made with an extrusion in family. On this panel there is an pattern.
However, now I want to allign that panel to a curved wall.. I was wondering if this is possible...?
Replies (34)
Message 2 of 35
Message 3 of 35
It belongs to the framing families, not the truss family.
Message 4 of 35
Are you talking about a Pattern-Based Curtain Panel that that is used in Divided Surfaces?
Message 5 of 35
Uhmm no I used family>create: extrusion: made a panel and put the patterns in it
Message 6 of 35
Uhmm no I used family>create: extrusion: made a panel and put the patterns in it. So it became a perforated panel
Message 7 of 35
I think you post on the wrong topic?
Message 8 of 35
Can you post the file please so we can see what you are doing?
Message 9 of 35
I attached a file with the problem. So the panel with the pattern should be attached to the curved wall. The panel will be the exterior cladding of the curved wall
Message 10 of 35
Like this?
Message 11 of 35
...or more like this?
Message 12 of 35
if so, Array.
Message 13 of 35
syman2000
Is this what you are aiming for? See attached
Message 14 of 35
More like this! It will be the half of the circle filled with panels. How did you do this?
Message 15 of 35
Message 16 of 35
yes how can I achieve this? @barthbradley @syman2000
Message 17 of 35
Move the panel to where it should be in relation to the wall's exterior face, and then use the Linear Array Tool to array the Panel in the y-direction, and then Radial Array Tool to array all of the linear arrayed panels about the curved wall's center point axis in the x-direction.  That make sense?
Message 18 of 35
did you notice the RVT that @syman2000 posted?  That's another approach you could use.
Message 19 of 35
Thank you for the explanation! I will try it!
Yes I saw the RVT file, I thought you both used the same method?
Has one method an advantage above the other?
Message 20 of 35
Depends. Are you practiced with Curtain Walls? If not, then I would just Array the one you've already placed in the Project and then call it a day.  😉
