I am looking to offset the base mullion on the Z Axis. There is a built-in 'Offset' parameter that moves it on the X/Y Axis, but not Z. The idea is to give the base mullion an offset of 10mm for Caulking/Sealant. If I give the CW a base offset of 10mm, then the rooms overlap.
Things I want to avoid:
I thought about placing a parameter in the profile, but this can't transfer into the mullion system family like it would with a nested family. Maybe Dynamo would give me the answer, but I thought I'd check here first. Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von Kev_D. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Yes I was getting the Computation Height error when doing that, but now I know to set the Computation Height of the Levels to fix this.
Cheers
