Beginner queries that are likely straight forward.
Beginner here.
Only two questions at the mo.
How do I quickly change a laid floor that is travelling through rising walls to stop at each wall?  I could lay a floor in each room separately and get my end result but that seems like a bad habit.
Also how do I take a snip of a section box view to add to a sheet?
Kind Regards,
Ciaran
RDAOU
@Anonymous
Sometimes what you called a bad habit is a more suitable practice...but you could do it the easy way lay 1 floor and use Join Geometry tool...Then switch Join order as deemed suitable (See GIFF Below)
