Beams' Projection in linked models
Mpcconsultora
Mpcconsultora
The methodology that we are having is that there is a modeler working in one file (modeling the building) and in another file, linking the model, another operator assembling the presentation sheets. Wanting to implement this modality we face a structural design, achieving an efficient modeling in Revit.
Then we started with the composition of the sheets and it was then that we had difficulties in the visualization of structural elements, such as the roof straps, which must be represented in the Ground Floor since the project has only one level.
Plan ViewPlan View3D View3D ViewLeft: Model not linked. Right: Linked model.Left: Model not linked. Right: Linked model.
What is indicated in red in the 3D view image are the straps that I can not visualize on the ground floor of the linked file. Maybe you can help me from another form of communication (link), I am willing to coordinate a meeting if necessary.
VG > Revit Links tab > click button under Display Settings > choose by Linked View > select the proper linked view from the list.
juanfelipecordoba89
I still can not visualize the projections of the structural frame families (beams) as they are seen in the last image.
Ground Floor - Linked modelGround Floor - Linked modelConfiguration - Linked modelConfiguration - Linked modelGround floor - Unlinked modelGround floor - Unlinked model
juanfelipecordoba89
Hello, even this question has not been resolved. Here I enclose a blog where the same questions that I have regarding the preyeciones of the beams of a linked model are exposed.
http://revitpilar.blogspot.com/2018/09/vinculos-y-proyecciones.html
