Beam system align to edge of support instead of centerline
Is it possible to have a beam system in which the beam handles align with the edge of the support member instead of the centerline? I want to be able to change the angle of the support and still have all the beams connect to the top left edge of the structural box (see image below).  I can't just change the justification line of the box to left because I will need to add another beam system on the other side of the box that would need to have a right justification.
ennujozlagam
hello, you may try to check it here previous thread. thanks
Click Here
This isn't exaclty what I am looking for.  My problem is that when I create the beam system using pick supports, it automatically aligns to the center line of the supports. Since my center support is 10 ft wide, I need the beam system to align to the face of the support instead of the centerline.
