Beam Features missing on IFC Import
Julio_Soto
Advisor Advisor
Julio_Soto
I'm importing an IFC model and I noticed some cuts did not show up. When I open the IFC model in any other open source IFC View the beams are displayed correctly. When I open it in Revit it's missing the top cut.  This is the first time using Revit to open IFC models. Is this typical for Revit?
What's cutting it?
Julio_Soto
It was exported from Advance Steel. Advance steel uses a beam shorting feature.
I also just noticed that in Revit the steel bracket at the top is shifted over and conflicting with the column. sigh 😞
