Beam doesn't appear
13 REPLIES 13
Message 1 of 14
halfon.raphael
850 Views, 13 Replies
Beam doesn't appear
Hello everyone,
I drew a beam system. In a section (not exactly perpendicular to the beam system). Some beams appear but others don't. Beams all are parallel to one another. Any clue ?
Raphael
13 REPLIES 13
Message 2 of 14
in reply to: halfon.raphael
Edit the family and uncheck Precut box.
Message 3 of 14
Hi Toad,
Is it this parameter you're refering to ?
I unchecked it but it didn't work.
Message 4 of 14
RDAOU
@halfon.raphael
Can you attach the file?
Message 5 of 14
Here you go. there's only one view
Message 6 of 14
So some beams are partially obscured by the floor because they overlap?  If they don't overlap then you have something like the below image?  Would that work?
Message 7 of 14
Beams do overlap with the floor above. What I would like to get is the YES picture (made with detail elements). What I get is the NO pic.
Message 8 of 14
RDAOU
in reply to: ToanDN
You can fix this by
  1. using Join Geometry and Switch Join order
  2. Replace the beams you have with the one which is attached (since it is oblique, Geometry need to be visible)
 @halfon.raphael  See GIF Below - Use the attached Beam family
Message 9 of 14
You could edit the beam family and set the 3d extrusion to be visible for all detail levels (coarse, medium, fine), reload,
then Join geometry the floor with the beams.
Message 10 of 14
unfortunately I'm using Revit 2019. Can't open your file. What did you change in your file "Chevron NEW" ?
Message 11 of 14
RDAOU
@halfon.raphael
A 2018 version of the family is attached to previous post
Message 12 of 14
It's weird : doesn't want to open in 2019.
My beam family (which I changed to draw the X when cut) has the 3D extrusion visible for all detail levels. But Revit  still says "unable to join"
Message 13 of 14
RDAOU
@halfon.raphael
Redownload the new family...the previous was 2022 ...replaced with a 2018 it should open in 2019
Message 14 of 14
Thanks!
