Beam doesn't appear
halfon.raphael
Beam doesn't appear
halfon.raphael
Hello everyone,
I drew a beam system. In a section (not exactly perpendicular to the beam system). Some beams appear but others don't. Beams all are parallel to one another. Any clue ?
Raphael
Replies (13)
Edit the family and uncheck Precut box.
halfon.raphael
Hi Toad,
Is it this parameter you're refering to ?
I unchecked it but it didn't work.
RDAOU
@halfon.raphael
Can you attach the file?
halfon.raphael
Here you go. there's only one view
So some beams are partially obscured by the floor because they overlap?  If they don't overlap then you have something like the below image?  Would that work?
halfon.raphael
Beams do overlap with the floor above. What I would like to get is the YES picture (made with detail elements). What I get is the NO pic.
RDAOU
You can fix this by
  1. using Join Geometry and Switch Join order
  2. Replace the beams you have with the one which is attached (since it is oblique, Geometry need to be visible)
 @halfon.raphael  See GIF Below - Use the attached Beam family
You could edit the beam family and set the 3d extrusion to be visible for all detail levels (coarse, medium, fine), reload,
then Join geometry the floor with the beams.
halfon.raphael
unfortunately I'm using Revit 2019. Can't open your file. What did you change in your file "Chevron NEW" ?
RDAOU
@halfon.raphael
A 2018 version of the family is attached to previous post
halfon.raphael
It's weird : doesn't want to open in 2019.
My beam family (which I changed to draw the X when cut) has the 3D extrusion visible for all detail levels. But Revit  still says "unable to join"
RDAOU
@halfon.raphael
Redownload the new family...the previous was 2022 ...replaced with a 2018 it should open in 2019
halfon.raphael
Thanks!
