Beam Annotation tool not working
juliefL3JKF
Message 1 of 8
juliefL3JKF
I have a student that cannot get the beam annotation to work for him, & I cannot figure out why. Both the structural tag & spot elevation can be place individually & they are both set to rotate with component. The beams are in a linked file, & the include elements from linked files box is checked. The ceiling plan is set to wireframe. What else could be causing the tool not to work?
Replies (7)
Message 2 of 8
Are the Beams actually in the Current View (e.g. not in Underlay)?
Message 3 of 8
juliefL3JKF
Yes, there is no underlay being applied. It works for other students, so it is a setting that is different, but I cannot figure out which one.
Message 4 of 8
Mike.FORM
Are you able to select the link? is this little icon in the bottom right have a red 'x' in it.
Message 5 of 8
juliefL3JKF
I can select the beam from within the linked file, but don't understand what that has to do with the Beam Annotation tool not working?
Message 6 of 8
Mike.FORM
If the select links was 'X'd then you wouldn't be able to select anything in the link when tagging.
Message 7 of 8
juliefL3JKF
Thanks for the idea, but I just tested that & the Select Link toggle does not affect the Beam Annotation tool. In another project I was able to use the Beam Annotation tool to tag the beams in a linked structural file with the X disabling Select Link showing.
Message 8 of 8
juliefL3JKF
I figured it out. It was the Discipline. The Discipline was set to Mechanical & the tool does not see the beams in Mechanical. Once it was changed to Coordination, the beams could be tagged. Thanks anyway!
