Basic options missing @ Ramp and Stairs
VenB
Message 1 of 10
VenB
Just wondering - is it possible to be added basic options like slope in degrees (Ramp) and a number of stairs (not "desired") plus the height of a tread (that actually works) for stairs... I have to fight it struggling to sort it quickly and effectively.
Replies (9)
Message 2 of 10
dyp4f
Good point. Post it in the Revit Ideas Forum.
Message 3 of 10
benschilders
@VenB , @dyp4f
For the stairs you could vote on this idea:
https://forums.autodesk.com/t5/revit-ideas/a-stair-tool-that-actually-works/idi-p/9658526
pyRevitHave a look at my idea: Material priority Revit quick start guide ┃Please accept soulution if my anwser solved your problem
Message 4 of 10
You set the start and stop elevations and Revit calculates the ramp or stair for you based on a few criteria set to them.  It is a godsend and I am wondering why you would want to calculate it manually?  Can you give a specific example?
Message 5 of 10
"Ramp" has a specific connotation in my neck of the woods and generally ADA governs our Ramp slope - not Autodesk or the Designer.  We would love not too build ramps frankly.
But, to specifically address to your question, I would suggest Floors and Slope Arrows. If you want the Floor to be "Solid" (like Ramp can be),you can make a Floor Layer "Variable" (in Edit Assembly dialog box), sketch the Floor WITHOUT a Slope Arrow and then use Modify Sub-Elements tool to change the end elevation.
Message 6 of 10
VenB
Because setting the start elevation - it works, but setting the stop elevation doesn't- it literally does nothing. Anyway, the purpose of the article - isn't it better if there are more than just one or two options for editing the ramp- just a multiply options that can be tweaked to save time and hassle.
Message 7 of 10
VenB
I will - for sure mate. So many revit releases and almost nothing to be changed in a better design performance.
Message 8 of 10
VenB
Modifying sub elements will not give you, for example 10% slope straight away - have to draw the angle in section/elevation preliminary. You can make it that way (that's the way I am making it) but that take 3 or 4 times more time than just say: 10% slope constantly, even after editing the ramp contour in plan it will keep the slope set.
Message 9 of 10
mhiserZFHXS
What do you mean setting the top elevation doesn't work? You mean the top constraint?
Message 10 of 10
VenB
Yes, the top constraint.
