Method for Applying Slope to a Floor in Revit
Context: When creating a floor that will serve as a platform for a railway station, it was necessary to divide the floor into two slopes. Each slope needs to have a maximum inclination of 1%.
Procedure Used:
Image 1: Longitudinal and transverse division of the floor.
2 Measuring Heights of External Points:
Images 2 e 3: Reading the altimetric points of the floor.
3 Calculation with Excel Spreadsheet:
Images 4 e 5: Excel spreadsheet for calculating the height of the central point and adjusting the floor slope.
Final Question: Is there a more automated way to perform this process directly in Revit, without the need for external spreadsheets?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Use the slope arrow tool. You can define heights or slope:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
You can use the same formula (with actual values) directly when input the point elevation in Revit. For example: = (2,9742/100)+0,4968
