single line text to multiple lines
arkitek2ss
arkitek2ss
is there a way to convert mutiple lines (i mean 100x) of text into single  multi-line text?
I imported a file and know ALL the text is single.
vitorbortoncello
no
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Open the DWG in AutoCAD, select all single line texts and use the command TXT2MTXT.
RDAOU
@arkitek2ss
It is possible to Join them into a single Text Note using Dynamo...
But if you are not into Dynamo or do not wish to use it then converting in Autocad to Mtext and Re-importing back to revit  is your only option
handjonathan
Hi @arkitek2ss
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ToanDN @RDAOU helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
