Automated way to apply slope on a floor
sc_formazione
sc_formazione
Method for Applying Slope to a Floor in Revit
Context: When creating a floor that will serve as a platform for a railway station, it was necessary to divide the floor into two slopes. Each slope needs to have a maximum inclination of 1%.
Procedure Used:
  1. Dividing the Floor:
    • First, I used division lines to split the floor both longitudinally and transversally, with spaces of 10 meters.
Image 1: Longitudinal and transverse division of the floor.
2  Measuring Heights of External Points:
  • After the division, I obtained the height values of the external points of the floor. These points are fixed and cannot be altered.
Images 2 e 3: Reading the altimetric points of the floor.
 Calculation with Excel Spreadsheet:
  • Using an Excel spreadsheet, I entered the height values of the external points and the distances from these points to the center of the floor.
  • With this data, it was possible to calculate the required height of the central point so that the floor has a maximum inclination of 1% on at least one of its sides.
Images 4 e 5: Excel spreadsheet for calculating the height of the central point and adjusting the floor slope.
Final Question: Is there a more automated way to perform this process directly in Revit, without the need for external spreadsheets?
vitorbortoncello
Use the slope arrow tool. You can define heights or slope:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
You can use the same formula (with actual values) directly when input the point elevation in Revit. For example: = (2,9742/100)+0,4968
