Autodesk product errors
!Dalton_Goodwin!
!Dalton_Goodwin!
All Autodesk products are not opening. They have worked all day just fine and when I open my laptop to get back to my drawing on AutoCAD16, it closed immediately. It wasn't that specific drawing because I tried to open different drawings in AutoCAD16 & 17 the same thing occurred (closed immediately with error). Also all products are acting in the same way, when I try to open navisworks16, revit16, and revit17 they close immediately with error. The AutoCAD16 ended with - AutoCAD Error Aborting - FATAL ERROR: Unhandled e0434352h Exception at 2ca47788h
The others didn't give me a specific error, just a caution sign.
Help please!!
Thank you,
Dalton G
dzanta
perhaps a microsoft update or security update occurred.  can you check those...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
!Dalton_Goodwin!
Thank you very much. Yes that is the problem. I uninstalled microsoft silverlight update and the Autodesk products worked just fine.
Thank you,
Dalton G
