@ToanDN wrote:
Since you have said he only has Revit 2013 I am quite confident that he has not used it enough, if at all. It probably was in a suite of AutoCAD/AutoCAD Architecture/Revit that Autodesk used to sell back then.
From my understanding, you are the house designer and the architect will be handling documentation for entitlement/biding/construction. If that is the case then you do not need someone with Revit, much less the most up to date version of it. You need someone that is good at creating construction documents using the software they are familiar with, not someone with an unfamiliar software a steep learning curve goes a long with it.
AutoCAD or AutoCAD Architecture are more than capable to create construction documents. So, if the architect are good at using then program then so be it.
You are correct, I am the designer, he is tasked with creating the documentation required by the municipality. However, my 3D model represents "design intent only" as I performed no load calculations, checked code as I built up the structure etc. He is responsible with making sure my design meets typical construction practices and local codes, hence he needs to pull cross sections at various locations from my model as opposed to starting from scratch in AutoCAD, at least that is what we agreed as a path forward if he can get something useable from my Inventor model.
Attached is a document I provided to the architect along with various CAD files. As you can see, the model has a fair bit of work in it, and would hate for it to be lost work.
It seems if I export to DWG selecting solids only, what I get in my Revit 2022 trial looks good, but I have zero Revit skills to pull cross sections etc to check what if any information was lost.
