Autodesk® Authorized Training Center - web validation, certificate of Completion
jvpantin2
jvpantin2
Hi community, one question: I approved a course of Revit at an local Autodesk® Authorized Training Center on 2017, receive the Certificate of Completion on a PDF file but now I want to web validate it in order to earn a badge or a virtual certification. I did registered in Autodesk Education Center (https://education.autodesk.com/) and my certification is there, but how can I do to link it with my profile e.g. as a badge?
Thank you,
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
s.borello
I have no idea.
PavelAnd
Hi @jvpantin2! If I remember correctly, you should go to youracclaim . There you can add your Autodesk account email and your Bandage should appear.
Best regards, Pavel Plotitsyn.
PavelAnd
I was wrong.... Your badge.  🙈
MostafaElashmawy
You should register at Certiport and Acclaim with same email of the test.
There you can see your certificate and your badge.
Mostafa Elashmawy
jvpantin2
This is what I have, an Autodesk Education account with the register of the course I completed. It's the same email I used for Acclaim and Certiport, but there is no way to link them in order to certificate or claim a badge...
I believe that you get badges from Acclaim after passing the exam (for example Certified Professional or Certified User exams). There are no badges after completing the Autodesk course. Only Certificate of Completion.
