Of course the job of the path of travel tool is to find the shortest path between A and B. But is there a way to edit it (kind of like the directions on google maps) so that it needs to go through or avoid certain spaces? I am trying to use it to see how far something might be if someone traveled this way instead of that way.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Select Path and add Waypoints. Waypoints tool is on contextual tab when you select an existing Path.
You both helped with this one, I had to update Revit (2020.2) and I was able to modify the path
