AutoCAD Intersect equivalent in Revit
ar_micahbaleciado
ar_micahbaleciado
Hi all, can you help me on this? I am "still" using Revit 2021 as per company and project requirement. I have an Inclined Wall with irregular shape.
So if I just use a wall and set it's inclination, I cannot edit it's profile. Since Profile Editing of inclined wall was only introduced to 2022 version and newer.
So I am looking for the "intersect"  equivalent of AutoCAD in Revit which AFAIK doesn't exist.
This is what I have.
The blue is the inclined wall, while the yellow is a model in place in which I need to trace over from the site. Now I only want to get their intersection pattern as you can see in the image after I Joined them.
any suggestions?
RC_RVT
Could you use a custom roof and slope that and then edit the profile of that in plan view? Not sure if you need the wall to be an actual wall in Revit or not though. I also don't have 21 to try it in I'm afraid, so I'm shooting blind a bit.
Simon_Weel
Or create a Void encompassing the yellow part and leave out the blue part.
ar_micahbaleciado
Thanks this will do for the moment.
ar_micahbaleciado
this is just a portion of the whole site.. if I use void it will be a lot of work coz they're all in different levels
