hello, i have a autocad file link into my site plan.rvt (revit file). i linked the site plan.rvt into my model and i cannot see the autocad file into my model. any suggestion. thanks
Solved by Alisder.Brown. Go to Solution.
A few questions:
1. Is the scale of the CAD file correct? DId you checked it opening the file in AutoCAD and checking the scale there?
2. Is the file visible in any view? If it was inserted or linked using "visible in this view only" It will only be visible in one view
3. Is it part of the list of files linked into your project?
4. Can you see the CAD file in the Imported Categories tab from Visibility Graphics?
5. Was the file inserted using origin to origin or shared coordinates?
Let us know.
BIM_Dreamer
Do the following, it should get your links visible.
You can create template from these view settings to apply to other views or just do this process for the few views you need the CAD plan visible.
Hope this helps
