Gutters seem to want to attach to roofs, and I need to attach one to the edge of a floor slab.
Are there any quick ways to do this?
b
b
Solved by loboarch. Go to Solution.
Make a slab edge family type using a gutter profile. You may have to make a new profile family and load it into the project. I suspect the gutter profile family is only able to be used for fascias. Just use the generic profile family template.
Thanks.
I already threw a model line onto the edge and attached the gutter to that. Next time I'll try this method!
b
Thanks.
b
And hey, I just did a slab edge gutter, and it worked just lovely.
thanks again Jeff.
thanks again Jeff.
Great. Mark this one as sloved!
Thank you, Mr. Hanson! 👨🎤
